Umbrella sports
Anyone know how to watch UFC events on umbrella through kodi? Where to click. I use to watch it on the crew but I switched for more options. Don’t wanna switch back unless I have too. I could use Troy’s kodi and just do a second one but I got one firestick and there isn’t enough room for two. Thanks yall
My best suggestion is signing up for an IPTV service. Not so sure you will be able to get UFC events on a Kodi addon consistently. There are several other sports APKs available for sports. If you search on here for sports apps and APKs, I am sure there will be plenty of info available.
I downloaded and installed sports fire , it works ok
I am not aware of Umbrella offerings Live Sports.
As @apoclines mentioned, Sportsfire or Streamfire work well. As well as thetvapp.to using a browser.
I think The Crew offers live sports but i never used it. There is also Mad Titan and The Loop as some other sports addons for Kodi.
Correct, Umbrella is strictly content on demand. No live streaming.
Install Mad Titan Sports . There are other sport apps such as The Loop and Sport HD along with others in which I can’t remember off the top of my head. Good Luck
Yes your correct the crew plays ufc events live. I use to watch it all the time but switched to umbrella. Gonna use Troy’s kodi clone and install
The crew. Thanks man!
