Ugoos Amlogic s928x versus Formuler Z12 and Buzz TV
If price is not an issue, which of these three boxes is the best? I know each has their pros and cons, but I as seeking some expert opinions.I have an ONN 4k Pro, and a Firestick Pro, but with the upcoming clamp downs, I am looking to change.
Thanks,
Kenny Mc
I applaud your desire for information but I think there are far to many variables in this hobby to get a single straight forward answer. As an example, 64 bit is now the standard in computing and 64 bit apps will or are becoming the norm, so that is but one small consideration as is future proofing. I have and use a P6L 256 Unlimited. Way overkill for what I use it for but provides me with a wide range of possibilities, especially with 32 GBs of DDR5 RAM. The latest USB. 256 GBs of internal memory making it easier for basic recording, and 64 Bit OS so 64 Bit apps can run on it, and the list goes on. Not sure there is a one box fits all answer.
No Miki that helps a lot. Thank you very much for your input. I am just trying to make the best decision possible.
Thanks again,
Kenny Mc
Oh by all means I understand fully and as said, I applaud your efforts. I just don’t want you to get mired down in all the details, it can be daunting.m
Boy, you got that right!
I’ve often heard that “nothing is for certain in the streaming world”. Many things can change in the blink of an eye.
I am fairly certain that most of the streamers started with the Firestick which has typically been a $20 investment. When people were looking for different option, came the rise of the ONN/Google, which fit most people’s budgets. At this time I moved to the Nvidia Shield, which was a big leap from the the Fire 4K stick. I was feeling that $200 upgrade was justified with the upgrade in memory, that the company was US based (for customer support), and it was just the king of the hill. But now with rumbling of possible OS changes looming, there is a lot of confusion on which way to go. There were thoughts that streamers would possibly be redeemed with a cheap Chinese box so that they could stay in a sensible budget. But far too many articles lately have warned against possible malware burnt into the box. So now the dilemma is, do I spend $150-250 on a streaming box that could eventually end up not working with whatever changes may be on the horizon.
For me, personally, it really has to offer, first and foremost, customer support in the event of any issues. So I’ve poured over threads here on the Insider to see what folks are saying how they have been treated by the manufacturer, when Issues crop up. Heck, when a Firestick quits working one would just buy another $20 stick.
Of those I would say the Ugoos SK1/Am8 Pro with the s928x because they have support for all HDR formats and audio codecs.
You have to decide on which is the best for you. What will your usage be? Do you want Dolby Vision? DTS or other HD audio? Need 64bit OS for gaming?
Every box on the market has a compromise, which ones do not matter to you?
Depends on what you will use the box for.
Specs P6L 256 Unlimited - Miki is right when cash is not an issue.
Nvidia Shield still a great device if you need official app like Netflix
Ugoos SK1/Am8 Pro also good specs
For IPTV - have to go for Formuler Z12 ultra
Thanks Mike. Really appreciate the input!
Thanks so much for the input Scooby! I’m pretty much leaning towards the Ugoos.
Thanks Jerry for the input. You are right, it is a puzzling decision.
I also have the BuzzTV P6L 256 unlimited and couldn’t be happier. Runs extremely fast, 64bit capable, very smooth with (imho) very sharp graphics. I have had mine for about 6 months and it has been glitch free. YMMV but I am totally satisfied with my choice.
Thanks T. Oh my, decisions, decisions!
I own 3 Nvidia Shield TV’s , 4K Firestick and a Z11 Pro .
Besides not having official Netflix app I really like my Z11 Pro . I actually replaced one of my Nvidia Shields with it
Thanks so much for the feedback. I am kind of leaning towards the Z12
Is it the shield tv pro you had? What is speed of device compared to shield?
Troy will post a review after he has used it
I like the Formular and Ugoos devices. I never had a problem with them. I don’t have a Buzz TV. So can’t speak on the Buzz TV. Personal preference I guess.
Thanks for your reply. Can you seen any difference in the performance between them.
For me they both work about the same.
