Twilight Kodi Addon No Results
I installed the Twilight app for Kodi but there never are streams available. Even older movies that I know should be available won’t pull up. Everytime I check a movie, it goes through it’s progression of showing whats available in SD, 1080, 720, etc and after it checks, a popup says no results. Very frustrating. What’s going on here?
How to Install Twilight Kodi Addon for Kodi 20 (FEN Clone) (troypoint.com)
Did you install the scraper properly? Also, check to make sure your RD account is up to date and properly authorized.
3.2.07 is the version currently for Twilight and it’s pulling tons of links here. :slightly_smiling_face:
I just installed and tested, like Papa says, it works great. Follow Troy’s tutorial from the link and you will fix your issues.
Did this issue get sorted as im having the same problem. Just downloaded today. Followed troys instructions to the letter. What do i need to check with scraper and RD? On first glance everything looks as it should but im no expert. Everything i try to watch says no source available. Had this previously when trying to use kodi apps and gave up so would be good to learn how to fix this issue is possible
My problem was my Real-Debrid account. It had expired. Once I reinstated it, it worked. Hope that helps.
There seems to be an awful lot of problems with different Kodi add ons getting a no stream available or no results. To much of a coincidence
Same thing for me. Was getting no results in KODI but my Real Debrid account had lapse.
Same here. Followed the instructions exactly. It shows sources while looking and then just say No sources. I can’t figure it out.
Maybe someone knowledgeable with AD can weigh in. I hate that RD is shutting down. It worked perfectly for me, and I refuse to pay Premiumize or whatever its called those high ass prices.
I don’t know they were shutting down…I just renewed for 180 days lol
Twilight won’t pull up streams just like what happened to FenLight. I uninstalled FenLight and reinstalled FenLightAM and all is good. Is there a similar fix for Twilight. I think both are run by the same people.
See these other options - Best Kodi Addons for Free Movies & TV (May 2026)
I’m a fan and still using the Twilight addon, as of last night. Have you checked for updates? And, as far as I know, FenLightAM and the Twilight developers are not the same. They are just based off of the OG Fen addon.
Also, interestingly enough, I’ve found links on Twilight that weren’t found on FenLight even though they both use Cocoscrapers. Go figure!
