Twilight: Hebrew language characters on some settings menus
I get Hebrew alphabet characters on a couple of settings menus and also on some movies and TV search results when using Twilight. I seems to only be happening with Twilight. I checked the all of the language settings I could find, but all appears to be in order. Anybody else have this happening? How to remedy?
I really, really like Twilight.
I’m assuming that the developer is Israeli. And most likely set up to provide options for Hebrew speakers.
Just go down to where everything is in English. That would be the “General” setting then everything should be in English. I’m fairly certain that you are unable to turn that off.
Hi Jerry…thanks for the reply. I’m pretty sure I tried that in both Twilight and also Kodi settings, but I’ll try again.
Thanks
