This is a really nice website. It has programming guides and EPGs available for full countries or even individual epgs for channels.
OMG these are fantastic. They are even working to load the missing channels in my Ali Baba sub. tx tx tx.
Just got saved to my IPTV arsenal of favorite links. Thanks!
I am surprised you as Mr EPG didn’t have those.
i just use this site
TV Listings- Find Local TV Listings and Watch Full Episodes - Zap2it.com
Nice. The main benefits of the site is the EPG. Guide is side benefit.
Thanks for suggestions.![]()
Can anyone tell me how to use A different EPG than default one that comes with my IPTV playlist on TIVImate premium? Or maybe A link to A video that explains it, Please?
I have A Great IPTV playlist but the default EPG only provides 40% of EPG information for USA channels.
I would really like to try this EPG source for my US playlist on TIVImate premium app.
Thanks in advance, RiZZo
Thanks in advance
Please use the search.
This has been covered many times. Lots to read and learn. Also troypoint.com has many tutorials that will help you along your journey. The following is an example:
Thank you for your help. I did use the search that is how I came across this thread.
The link you provided I used to set up my tivi mate app many months ago.
I was hoping to get suggestions or information on how to choose which 3MU to use from epg.pw and if I just enter the epg 3MU as I do A IPTV playlist? I revisited the tivi mate set up guide from troypoint and was not clear on how to add A different EPG provider other than the default one that is included with my IPTV service.
THX RiZ
There are many threads that actually answer your question but ok I’ll help. To begin with, m3u8 contain the XML file or the EPG file that you’re looking for, if you want to add an epg, then you just simply go to EPG sources under the settings invTiViMate and if you have the proper URL for a guide you add it in there, name it whatever you want, then go to your playlist. Look up epg sources and activate the source on the right by sliding the button or clicking a button. Activating it whatever you want to call it. Settings - EPG - EPG sources scroll to the bottom, click add source, then either enter the URL-or paste from the Clipboard. That’s as easy as it is, then when you’ve done that, you simply go to settings playlists, click on whatever play list you want to use that source on, scroll down to EPG sources. Click on it and then you will see the sources below that you can manage. Enable them, take them off rearrange the priority all in EPG sources.
Thank you very much. That is exactly the information I needed.
When I searched the troypoint for information on how to do this many threads showed up and this was the best 1 I found.
Those instructions you just provided should be posted as how to use and add other EPG sources to tivi mate.![]()
Thank you for your time. I do really appreciate it.
There are at least 3 other threads with these directions in them. I answer this a lot as well as provide sources. But You’re welcome. PM me directly with any TiViMate “how to” questions you may have.
I have read the earlier posts on this subject and like what seems like a lot of others, I am missing something that I am sure has been shared before. I just don’t know what I am missing. I have a playlist that has an outstanding EPG ( let’s call it Sub2), I open another playlist (call this Sub3) where the EPG has lots of holes. I go to settings/Playlists and add the url from Sub2, I set the url for Sub2 as the default EPG source for Sub3. Refresh playlists. The holes in the EPG for Sub3 are not fillled in. Where am I going wrong? Also like others have asked, Do I have to point each channel separately; one by one?
That’s the difficulty when trying to interact with playlists, and specifically channels, from all over the world. They have to have identical identifiers for an EPG to load for it. I use Tivimate and on all my playlists I have about 8 EPG sources enabled and have my Tivimate set to update every 24hrs and on start up as well. But there are still some holes but fortunately not many. In Tivimate you can long press on a channel then in the popout choose the assign epg and do a search. It’s a bit of an art and there are EPG services that can help a lot and they’re pretty inexpensive.
Will Streamvault honor Gracenote channel id from zap2it to pull EPG?
zap2it shut down and is gone.
The Zap2It TV listings are still available, just moved to another site. Search for “Gracenote TV listings” and you will find some links to the site. Depending upon which link you choose, you may need to sign-on to your account, and choose “TV Listings” from your profile name to see the same listings that Zap2It had.
Good morning @itzme . The Cordcutter article has the site that has supposedly tried to pick up the slack listed. Have a super week.
Thatz where I C & P’ d that from…![]()
…and Good Afternoon to you…
