Tubi tv on firestick
Is it possible to install the Tubi tv app on my firestick? I am based in the uk and I know Tubi isn’t available in the uk. But I do have express vpn. I set the vpn to the US, but it still says the app is unavailable.
I did look on the troypoint website for a solution, and did find his page about installing it on kodi. Not sure if the details on that page are out of date now as the install would not work.
I did try searching the forum but couldn’t find much of help.
Does anyone know of a way to install on the firestick please?
Morning @TKTrooper,
If you haven’t tried, change vpn your to a server in US.
if you cant get it try onstream works well
You can try the following link.
http://bit.ly/tubi854
https://www.techdoctoruk.com/tutorials/
Scroll down to find Tubi TV and follow his instructions.
You can use a server in Canada as well. Tubi is actually an inherent app on one of our major TV providers along with many other apps. Tubi has great music concerts and musical documentaries. Its all Ive ever used it for.
There’s some modded Tubi apps that are ad free. Used to get them from Unlinked and other similar apps
Unfortunately that one doesn’t work either - “parse error” or some such message.
He does give a link to an alternative page - but that page doesn’t exist.
What VPN are you using? Some VPNs have servers in the US that manage to bypass georestrictions on certain apps.
