This is the best iptv player out there free ,all free epg ,recording good interface better than all the ones recommended, stremio rubbish sparkle tv rubbish tivimate rubbish smarters pro extra try tub player simple quick smooth and free
Oh gotcha, Tub Player…doesn’t look like a bad player.
Stremio isn’t an IPTV player. And with so many great new ones out there with cloud capabilities and amazing functions including easy recording like you mentioned especially without the need for the System Picker I know I’m G2G.
That post would deter me from wanting to try it.
Does it have timeshift or recording capabilities?
where to download?
But make sure you note their TOS. Once you add a playlist they keep all your info including username/password, for that Playlist, and you must delete it, or delete the app, in order to remove that Data. Also contrary to the initial post it does not contain it’s own EPG.
I’d be interested in a downloader code for this as i’d like to sideload it to a couple of older boxes i have to test it…anyone know of one?
thx
@Comtech …
Completely free to use — no subscriptions, no limits, forever.
Downloader code coming soon.
I still prefer OwnTV for a free player
Are commas and capitalization also rubbish? You’re trashing apps known as the best for years and calling them trash. You lose credibility instantly. If you would have said this app is really good and I think it’s better than Tivimate, then maybe I might look at it. Calling every other app out there garbage is laughable.
