TROYPOINT Toolbox not working
Hello,
Anyone know if the toolbox code is working? I am trying 250931 and getting "An unknown Error has occured. Check your URL. I have also tried the direct link.
Thanks for your help.
Open this in a browser TROYPOINT Toolbox
Working fine for me using
Or @Explorer s link, and good day Mr. Explorer. I hope you and yours are having a wonderful holiday weekend.
Yes it’s going good thank you Miki, hope you and yours are having a good holiday weekend
Thank you for your responses. I have tried it on a new firestick and it works fine. Older firestick - doesnt work. Is there something I maybe doing wrong, or just doesnt work on older firesticks. its just a browser link so dont understand why it wouldnt work.
Make sure you have downloader on the firestick, I just tried it on my 4k onn box and it will open. Sorry I don’t have a firestick
Silk is the internet browser on the sticks and is optimized for the FireOS. I only ever used downloader to get APKs.
Silk is the internet browser on the Firesticks and is optimized for the FireOS. I only ever used downloader to get APKs.
I accidentally deleted MX Player Pro from my stick and when I went to download it again the toolbox download said the same thing to me (Unknown error and check URL. I tried another link and it worked, but I couldn’t get MX Player Pro so I’m having to use Kodi for audio.
I opened the toolbox and when you hit the download button, it says Unknown error, check your url.
I have a year old firestick and the download just won’t download from the toolbox.
Have a look at this link and make sure you have unknown sources turned on.
When I get that I have to turn off my VPN
Ahhhh…Didnt think about that causing an issue on the firestick. Will try that. Thanks.
Still will not download even eith VPN turned off.
Thanks, Rog. Immediate fix. I see why searching is highly recommended.
I’m having the same issue
Help please. I am setting up a new Dcolor google tv box. I have activated developer mode and usb debugging but when I try to download anything from Troys toolbox I get a Forbidden message, I have set up boxes before and this is the first time this has happened
@tuck3000 ….i know you said this isn’t your first time so don’t be offended with my questions, but….are you using the Downloader app while trying to access TP toolbox ? and if so, when you installed Downloader did you give it permissions, in addition to having the developer mode active along with usb debugging ?
Help please. I am setting up a new Dcolor google tv box. I have activated developer mode and usb debugging but when I try to download anything from Troys toolbox I get a Forbidden message, I have set up boxes before and this is the first time this has happened.
