Troypoint Toolbox cookies problems?
Hi, Trying to update Kodi following your video. Tried to install Troypoint Toolbox with Downloader on my fire stick to update Kodi and received a box that said:
“This page requires cookies to be enabled in your browser settings. Please check this setting and enable cookies (if disabled)”
toolbox would not come up.
How do I get to a cookie browser setting?
Which browser? Browser in Downloader has no options for cookies?
Thank you in advance
Hi Dario welcome to Troypoint, you can get the Troypoint Toolbox downloader code in here.
Toolbox code is 250931
@Dario Try disabling your VPN momentarily if you are using one and see if that clears up the Cookie problem.
Thanks but I already tried turning off SurfShark then reinstalling Downloader then downloading Toolbox with the same results.
I am missing something. You don’t download the Toolbox you just keep the link in your favourites. On the Sticks you can use downloader or bookmark it in the Silk browser.
Having the same problem with downloader app cookie settings preventing internet access from Downloader App?
Just tried again this morning and it opened to the toolbox link. I was able to install current Kodi App.
Thanks again
Yes you accessed the toolbox and can download from it but you can’t download the toolbox itself. Nor can you install it. lol.
All Downloader codes I have tried are directed to Robot Challenge Screen??r=%Fxxxxxxxx
request at bottom of page reads “Please check this setting and enable cookies (if desired).”
There are no browser settings in Downloader. Silk browser is down and unavailable on amazon???
I just checked Amazon and it’s there for me to download. What version of downloader do you have? It’s in Troys toolbox
I know, that is where I downloaded it today > Problem is it only works with VPN off.
Is that something to be ok with ?
Nope. Try another download from someplace else. Uninstall the one you have though.
Easier said than done, silk is down to and unavailable on Amazon. What browser are u using?
As I mentioned, Silk is available for me. No idea why you can’t get it. What device are you using. Multiple issues with apps may indicate a device or configuration issue.
Just reset my Firestick Max because of issues with silk and downloader. Now I am trying to replace all my apps. Have downloaded downloader twice and sill cannot replace silk from Amazon.
Log onto your Amazon account on line and get the downloader and Silk added to your apps that way. Once you sync your device the app should be available for you.
no can do, firestick is not registered to my account
How have you registered the stick? It needs to be registered.
When I encounter this problem, I turn off VPN install what I want and then turn back on. The main thing here is making sure VPN is ON when using the apps. Just make sure you turn VPN back on prior to launching the app for the first time. You can also try changing VPN servers in Surfshark to see if that fixes the problem.
