TROYPOINT Toolbox connection
When using DOWNLOADER on my Fire TV, I am trying to get to the TROYPOINT Toolbox using he given code (250931), it will not connect. Instead I get the following message:
An unknown error has occurred. Check your URL and connection
What can I do in I this case?
Try entering
troypoint.com/tb
try.
troypoint.com/toolbox
That’s the correct Downloader code - I see no issues with the redirect right now.
You can plug in the url directly and see if it works for you…
Hi,@keithmac :waving_hand: I had similar problem, yesterday. Kept telling me it didn’t recognize me as human. I had to turn off my VPN and then it worked.
Hello, unfortunately we are under a DDOS attack…this will be taken care of shortly but in the meantime you may need to deal with captchas on our website to prove you are a human. Sorry for the inconvenience!
Patachou - thank you !!! That did the trick - much appreciated.
Thanks for the explanation and solution, Troy :+1: You are the best!!!
You are very welcome,@keithmac!! :+1: :raising_hands:
