Trakt Authorize Diggz AIO 1.9
I try to authenticate my Trakt and the screen pops up i enter the code on the website Trakt says all good, but the pop-up nevers goes away, and when i exit and come back Trakt is not Authorized, there is an error saying Account Manager has an update but no way of updating and when i check the release is correct. End result no Trakt’s. Unloaded and clean reload twice no luck, any clues
Its a known issue and mentioned on the Diggz Forum. I must have updated before the issue because my Trakt account is linked and working.
The Chef stated in a Post that it has nothing to do with the build. Doesn’t say what the actual issue is though. Account Manager?
My AM version is 2.6.3 if that helps
I can send you the Forum url if you like and you can ask questions or find out when its resolved.
A possible temporary solution. Disable the trakt menus and the Trakt error message should disappear until the problem is fixed.
I am going to try and load the build on a fork and see what happens.
I just loaded 1.9 on Troys fork and my Trakt authenticated without errors. I did notice that it took a little longer from the approval on the trakt app to the window closing on kodi. Id estimate about 15 seconds. Normally its about 1 second.
Im using my Nvidia shield tv pro. I bet on a less powerful device it would take longer. If that is the case with you, I’d suggest giving it extra time than usual to load everything and authorize.
Good luck.
Thanks for the information my is 2.6.3 also.
I found a back door round it I went to the Add-ons and opened the Trakt Add-on and in there you can authorize and it worked!!! All good now.
Good to know. Sound like its possibly a AM error. But not sure why mine is working.
Someone on the other forum says the issue is fixed. Probably explains why i had no issue when testing.
