Sometime over the weekend of January 30-31/2021, all the torrentio streams disappeared from the Stremio app. And when I tried to reinstall it, it was nowhere to be found. Are they having issues? Is there a workaround? Stremio had become our go-to app for streaming over the past few months and we are really missing it!
I have been using Streamio for months now and have not had a problem. Cinema became too much of a headache to deal with. I still see the Torrentio addon. I did a uninstall/install and added Torrentio. Working fine.
Stremio had become our go-to app for the reasons you describe. Really disappointing we can no longer get it to work. Even tried uninstalling and reinstalling, but still no torrentio addon available. Many others on Reddit describe the same problem. We keep hoping Troy will post a fix for us.
I just installed Stremio and when I searched the addons for Torrentio, the only options available were the Lite version and a Brazuca version (evidently for those who speak Brazilian). There is NO Torrentio - by itself - available. What do you suggest?
Use the Lite version. It worked for me.
here you can add torrentio addon to your stremio apk : Torrentio - Stremio Addon
Welcome to Troy’s little bit of cord cutting heaven.
A similar link to what I posted. If you add the following link into the Stremio addon search and enter it you will get the full json list.
https://danamag.github.io/stremio-addons-list/catalog.json
Torrentio still shows as a loaded addon on Stremio. But nothing loads when you click to open a series or movie. Only paid subscription links show up. I downloaded AIO and it works very well. This just started within the last 2 weeks.
Not sure what the problem is. My Torrentio, Torrentio PM and Torrentio RD all work just fine. I do have to use a certain set of VPN IP addresses in order for them to work as Torrentio seems to have blocked a huge swath of VPN IP addresses. For me I get the best results with a Vancouver server from 100-190.
I opened Stremio last night after a few weeks dinking around with IPTV Series/Movies and I have zero Torrentio links that show up. Comet, Media Fusion work fine. Not sure what’s wrong. I’ll probably re-install BOOTSTRAPPER over top of my current BOOTSTRAPPER and maybe that overwrites or resets something.
Torrentio has blocked a pile of VPN Server URLs. I have to use ones below 199 in Vancouver Canada for my Proton to get them to show. Then once I have switched I have to force stop and clear cache and twice even restart my P6L.
1 other question since you are a Stremio guru.
If there is a link with a
, do we want to avoid these? I don’t understand where it’s downloading but I’m thinking we don’t want to do that.
I’ll try changing VPN servers and see if Torrentio shows up.
Thank you.
It’s my understanding that those are downloads and they are downloading to your debrid account.
I had a huge issue with my Stremio when I decided to do the Android 16 update to my tablet. I literally had to delete my entire account that I had had for years. It corrupted absolutely everything. I even went into my account on Stremio web and deleted everything and added the .json manifests not even using the usual community addon sites. No go. So now I have started from scratch. No fun.
Did you get Torrentio to work? I did some testing and before switching servers every time, I found it was now necessary to clear cache in Stremio. I found a VPN server in Illinois or Texas worked just fine, and Torrentio RD and PM showed up and worked perfectly. I also found several issues if you are using the latest Beta version of Stremio, stick with the stable version, and if having the audio drop out issue, be sure to use the “Tunneled Playback” option in the settings.
Torrenio still not showing up but I confess, I just keep scrolling to the right and select a Comet or Media Fusion source. It’s a new device with the 64 bit version and haven’t messed with switching servers. If I can’t find a good source, I go to Kodi (where Torrentio no long works either) but tons of Pirate Bay sources populate.
I think I’m a lazy streamer but will get to fiddling eventually. I may wipe the app, go back to the original version you suggest, do BOOTSTRAPPER and I’ll switch audio if I need to. I’ve had no audio issues to date.
Thanks for circling back. I’ll keep after it but I’m in slow motion
Slow motion is good. I was using the 64 bit beta version from Troy’s toolbox and I had major issues with ThePirateBay+ generating an Unsupported source popup so I switched to the stable version and all is good now. I did find when Torrentio did not show up I had to clear the Stremio cache, but did not have to force stop, and then torrentio showed up in both a Texas or Illinois server. Hopefully this will settle down over time as many are having the same problem. I now have a list of Proton Server locations that work for Stremio, Torrentio and myself. Have a buffer free day.
@Miki Did you ever give BOOTSTRAPPER a go?
I noticed in Troy’s review of TorBox today that he wasn’t getting any Torrentio sources in Stremio either as he zipped across them in his video.
I’ll eventually fiddle with my Stremio and see what happens Many thanks.
