Yeah I never blinked an eye with the Torbox TOS changes. Doesnāt concern me at all. Let me know when an end user actually gets busted for using a Premium debrid service. Maybe then Iāll care
Iād have to agree. I think Iām going to sign up for it. Iām on the 24 hour trial right now. Aside from the TOS concerns many are freaking out about, I canāt find anything bad about it. I just tested out a whole bunch of old and newer movie and shows. Plenty of links and not a single one of them broken. Everything is cached.
The chances of authorities coming after an end user for streaming (not even talking about downloading or torrenting directly to your device) is about the same as a stranger recording you jaywalking and reporting it to the police and expecting them to do something about it.
Signed up with Torbox using Proton mail and paid in btc. Always use a vpn. Donāt think Torbox have any relevant personal information. Safe to keep using, or not?
Alternatives?
Tbh, followed advice from main website earlier in the year to set up stremio on Firestick and apply ad ons, then subscribe to TB. Havenāt really got much of a clue what it all means, how it works and in particular how stremio ad ons work along alongside TB subscription. Weāve just been happy with the fact that it does seem to want to work and we get to watch stuff. What now?
I never stopped using Torbox when they updated their TOS and have not experienced any changes. Plenty of playable streams. Canāt help you with Stremio as Iām a KODI user
Btc very easy to buy and use
What else do you use if Torbox then deactivated from add ons?
I use Premiumize which I have a 3 yr sub for and Offcloud which I have a year sub for
Thanks. Iām new to this. So both are whatās called ādebridā services, and when linked with add ons, through stremio for example, then they do some piece of work for the add on in finding content?
Is it possible to use the add ons without a debrid service?
Saw in another post you also use debridio?
Debridio is a source scraper and usually finds the best sources.
The site search will help you find threads to read and gain knowledge.
Thanks, thatās really helpful.
After some consideration, think Iāll remove Torbox from my stremio add ons and go for Premiumize instead, even though thereās a fair bit to go on my TB subscription.
Do you know if itās possible to keep all the add ons in place on stremio and simply replace TB settings with PM instead?
If the option is in the addon to choose a specific Debrid service then you can either leave TB enabled and select another Debrid service like PM and simply add itās API key, or deselect TB and select PM. Should work on most addons.
I find Torbox is adequate but doesnāt play a lot of sources. I still keep getting a lot of errors that states that Debridio is downloading to wait. It never works. There has to be something I either have to turn on or off. The VOD I have on my IPTV plays them all with no issues. Torbox supposedly just did a big update but not sure if I need to do something to update or does it do it automatically. Get real frustrating at times when sources show but canāt play
@Remy yes the Torbox Discord had an announcement yesterday about the major upgrade to v9.3 Iām pretty sure this happens automatically for you. Iāve been using debrid services for a long time and to my recall never had to do anything on my end to upgrade.
Not sure what you are using but I am getting tons of sources from Torbox on both KODI and Nuvio
@SoloWarrior Itās almost time for Black Friday deals. If I recall, those that partook last year will get the same $23.xx renewal for 12 months. I did but I cancelled when the terms of service changed.
The only problems I get is in TV series where some of the episodes are cached and play well but others arenāt and wonāt play at all. Strange that all of episodes of series arenāt
@GraceWilson looks like you are corrrect. when I go into manage my subscription it says $23.10 every year
Just curious. Are folks renewing Torbox when paid subscription completes, just letting it expire, or doing an immediate delete account, because of the change in the TOS that Troy raised concerns about?
BTW, my biggest issue was too many non English movie for show links. After going English only in nuvio that was solved.
I cancelled my sub immediately, but that was a personal choice based upon their TOS which seemed to change by the hour and were never clearly defined, not because it didnāt work. I have 2 alternatives.
