Tkbloat can't get to work on the new 4k max firestick
I bought the new Amazon 4k max 6e and downloaded the tkbloat from the Troypoint toolbox using downloader. It will install but show blank. nothing there to select. Any help please.
I’m thinking it is not compatible with the new Amazon Fire OS 8, which is based on Android 11.
You will probably find that with some other apps also. Os 8 appears to be a problem that they need to fix!
