I’ve always updated to the beta and knock on wood, have never seen an issue
The first comment that I read as I turn on my tv and see update message
4.5.0 is released. This morning it asked if i wanted to update. Usually i do a backup up and uninstall, but i just installed update and seems to be working great.
I have mine set to autoupdate. I’m using it now so I’ll check. Still 4.4.0 (Premium) Clicked on “Check for update” and voila there it is. Updating now Tx for the info. There we go Version 4.5.0 ( Premium) Doing a backup now . There all done without issue. I highly recommend that everyone create a new data backup after an update for TiViMate. Thanks again.
think mine updated a few days ago with analiti update
My first noticeable difference is in picture quality. Slightly brighter and sharper picture. Transitions are quicker and channel loads slightly faster. Maybe factors other than the update, but these are two visual differences I note. Going to dig into settings and see if I can find anything new.
Settings >appearance >tvguide>channel sorting > show favorite channels first
Lol. Yup. You’re fast.
Yea,… but don’t really see what it changes,… looked in favorites, and groups, don’t see a change
ive always kept mine to sort by watch time which basically sends favs to the top,
Ok. From what I see, when activated and say you have a Samsung playlist, the first channel in the list is “All Action”, now if you select another channel and make it a favourite from that playlist, then it now is listed as the first channel. If you have multiple favourites from a playlist then when you open that playlist your favourites appear at the top of the EPG in alphabetical order.
