Tivimate Tips and tricks
Hey,
What are some of the best Tivimate tricks and tips for customization and just day to day features.
I recently discovered a new code addition that extends the EPG displayed. On my epg they usually only show 24 hrs and I wanted more, this worked although not every channel loaded the extra days.
settings>EPG>EPG sources>click on the source name>EPG URL>on the end of the url entry add
&next_days=7
Worked for me. At least better than just the 24 hrs.
After adding, back out, close Tivimate, clear cache, restart Tivimate, wait for EPG to update and now you should see channel guide past the 24 hrs.
Going to try a second list with just 3 days ahead.
NOTE: Updating playlist/epg now takes a bit longer.
this guy has some good videos.
Our very own @Jayhawks659 made one as well
I tried this Miki, it didn’t work for me on my 4K Maxx.
Worked for me but only certain channels and I only gained 24 additional hours. If the supplier doesn’t have an extended EPG then you’l only get as much as they do have. Oh well it was worth a try. Maybe other suppliers it will work.
