Does anyone notice on tivimate that there is a movie section and tv shows section? I have been using tivimate for quite some time now and never noticed it before. But not everyone has it.
all depends on the provider, but its always been there.
Yes, but it does not appear for other people who have the same provider. At first I thought it was the version of the tivimate but it still does not show up on theirs. Just puzzling thatâs all.
Itâs on all my providers and has been since I installed TiViMate under Xtream Codes Parameters where you can turn on or off âInclude TV channelsâ or âInclude VODâ.
I have never not seen the TV/Movies/TV Shows/Recordings, etc on the left on Tivimate. Whether anything is in the Movie and Shows categories, depends on your provider and what you pay for. If you just pay for live TV, those categories will be empty.
I know you can go into setting and edit the list to remove the ones you do not use. Maybe the version they got was an âeditedâ version that did not have the âmoviesâ listing.
Could well be. Ya never know whatâs inside a hacked APK. I pay for it as I prefer to support a dev, and get the official version.
I just want to thank everyone for your comments and insight, it is much appreciated.
Can anyone tell me how to contact tivimate for support. I have tried everything and they do not respond
If it has anything to do with something other than TiViMate app itself they will not respond. So they ignore things like " why canât my IPTV sub load? Why doesnât my EPG load" etc.
Are you using the âTelegramâ app to contact them? It is the only way I know of that they do support. I have used it several times successfully.
They are on Discord as well. But like Miki said, Iâm sure they get so many questions about the IPTV services they just donât respond to those. If it is directly about the app, I know they will help.
I have been watching both for for around 2 years. I stumbled on it myself. Been watching both occasionally and enjoy the content
Hello. Is TiviMate easy to install and use?
It certainly easy to install and get going with, but you need the âCompanion APPâ for your sub. For all the things we do it takes a lot of learning, but there are lots of articles and pists here that can help. Advanced settings just take time, but this APP has a ton of valuable options. I highly recommend a âlifetimeâ sub which was $35 when I got mine.
Whatâs a Companion app?
The tivimate companion app is in playstore & its the app used to purchase a premium subscrptn & manage the 5 devices that yor allowed with premium
Then u use that email & psswrd to unlock all the killer options in (5) tivimate players
hthâŚ
So companion App provided the URL OR XTREME code?
No. The companion TV mate is a premium app of TV mate and it gives you the TV and movies sections the groups. The favorites. Only your iptv provider gives you the extreme codes or the mu3 code.
Also in addition to what the others mentioned, TiViMate âfreeâ is extremely limited in what you can do, purchasing a lifetime subscription using the âcompanion appâ opens up a world of configurations that make your IPTV experience much better with the ability to make it unique to you. It does take time and some effort to find all the settings you want, but there are tutorials and lots of threads here to help you along your journey.
Have fun and STREAM ON!!!
