Does anybody know if I setup a recording on tivimate with firetv cube if tivimate must be running? I want to setup a recording while out of town. Can I shut everything down? Any help would be great,
In my experience your device can be in sleep mode but you have to have the app running in the background. So don’t force close the app or completely disconnect your device from power.
sup Ron & welcome…
Another option is to go into…
Settings…
Other…
Reminders…
Down to Wake up from sleep…
& put default on Watch…
Then set the reminder the same as your recording…
HTH…
Thanks for the help folks!
I record all the time when the TV/Fire TV Cube is off. Just set up your recording. I have a show I record that I have set up as a daily repeat under custom recording.
Happy New Years everyone. Does anybody know if tivimate will save other than ts filetypes. My iPad pro won’t play them. I have looked around tivimate, but couldn’t find anyplace to change saved filetype? Any help would be appreciated. Thanks
Hi Sketch, do you know if tivimate will save other filetypes other tan .ts files. They won’t play on ipad. Thanks, Ron
Hey Ron…
Nah I’m afraid that’s it for now…
You’d probly have to convert from .ts to mp4 if you really need it…
sorry bud…
Hi Ron
all you need to do is install VLC media player,it’s free , on your ipad and it will play those files for you
I have VLC installed. Once I open vlc, how do I select a file on my nas server? Can’t find how to select or open a file? Is there a place on ipad to tell it to open .ts files using vlc?
