I’ve been using Tivi Mate for over a year now and need to be able to use it on more than 5 devices. is there a way to get more than 5 devices on the Tivi Mate Companion?
I have on more than 5 devices but don’t use on all of the same time so I float some devices with each other. call one connection like bedroom tv/tablet and activate one will deactivate the other. I do this in tivimate.
If I were you, Tivimate is so cheap, I would make a new username and purchase another set of 5 connections.
Also, WELCOME!
Exactly what I did. Now I have a few extra connections if needed
I’ll be working on the new username purchase idea!!! not sure how TiviMate companion (Blue Stacks)will handle 5 more devices to keep track of. I just retired so I’m not a computer guru by any means BUT I will try anything you guys suggest. Been big fan of TROYPOINT for years but now I can get a better grasp of whats going on here. Lot more time on my hands now!! THANKS AGAIN
Just make sure to name the device it’s on in the TiviMate app to make it easier. I labeled like “MeCool KM2”, “Formuler Z10” “Nvidia Shield Pro” etc.
I purchased another Tivimate account a couple of years ago for the same reason. The price is cheap and you don’t have to deal with work arounds.
