Tivimate hiding passcode
Is there a way hide passcode while using tivimate?
Sorry not sure what you mean by hide passcode. Are you are referring to your Xtreme code IPTV login located in your playlist?
No, you can’t.
Using xtreme codes on tivimate, looking to mask passcode or user name .
You can use parental controls and set a pin for settings etc
Sparkle hides them.
Not familiar with sparkle at all , sounds good
If you go the Parental Control route per @TXRon option. Then you will need to block both the playlist and epg because your info is displayed on both.
Sparkle is a good player and has great potential. The dev is quite active with his project and there are a couple of support groups available.
However, it is not nearly as good as Tivimate.
Actually, if you really need to secure your login info. Then I would do what @TXRon suggested. This locks the entire playlist and epg categories. The only drawback is you can’t do a manual update of your playlists or epg until you unlock those categories. Although, if you have set your playlist and epg to auto update. Then that should suffice.
Also, you can’t add or delete and epg or playlist without first unlocking it.
Sparkle TV - IPTV Player - Apps on Google Play
https://www.reddit.com/r/SparklePlayer
