Thank you I’ll give it a try!
I did what you suggested, worked great, now though, I’m getting a “Parser” error
Post removed by user.
What streaming device are you using? On a firestick you can force stop tivimate, clear cache and restart
I use a meecool, 7 deluxe
No problem with my tivimate working great
It seems like with the upgrade 5.0. the recording is a lot more accurate less buffering.
Having to test mine out some more on both internal and external as the one I set to record to external quit after 6 minutes. Could have been buffering though.
