Tivimate 4.2.0 beta in the works
Downloader 71461
Wish they could figure the recording problems for longer recordings.
Here is the Downloader code (71461) for the update to 4.2.0
This is the link if you wish to join the Tivimate Testing Program. Sign in - Google Accounts
Uninstalled 4.1.0, installed 4.2.0 and used 4.1.0 backup with no problem, some new features are easy to find. Working good so far.
Link for tivimate reddit
Stew with the scoop… & PF with the membership card…
You guys are on top of it, way to go as always…
& Thanx
If been running it all day and see no problems
Up-graded this morning and all is well
TV’s…
Phone…
Test Pilot…
Membership has its privileges…
If Tivimate would just import my ota channels from Tablo I would be all set
Thank you my friend for the info.
Totally agree, being able to record on the external usb would be perfect.
Please, please, I don’t know about this new update, please explain, someone in a previous post said that you can change the colour of the scheme from the drab grey to different colours ( EUREKA ), don’t even get me started on EPG’s. Thanks as always. Jimmy.
Sup Jimmy…
The color change is not new… (since 4.0)
Settings…
Appearance…
Down to Background & Selection color…
hth…
What are some good choices for IPTV compatible with Tivimate, I’m having trouble Thanks
troypoint iptv at DuckDuckGo
