TiviMate 2 Media Sources Playing at Same Time
trying to access a channel that won’t play because it thinks 2 media sources are playing at the same time. Any thoughts? Thanks
Clear cache, log out of TiViMate, reboot your device, open TiViMate and log back in.
Yep, probably the answer staring me right in the eyes
Have run into this many times. The only way to get these apps to work is to be ready to clear out memory. Also most providers only allow one stream. Have found that using a DUMMY channel from a generic free provider helps the app work. Then you select the channel you want to watch, after browsing and updating the EPG.
Not sure what you mean. I have 5 connections on my sub and can play 5 simultaneous streams. TiViMate allows me to have multiple windows open at the same time.
Nice in five connections. I have only one.
All the services I’ve ever dealt with have a minimum of 2 connections. 5 connections are just $115/yr.
Talking about connections, how many are you supposed to have with TM? I go to about and it shows premium but not connections
You can play up to 9 using the multi-screen feature.
If you mean iptv services. then you can have as many as you want. I have had about 15 different m3us on my Tivimate at the same time.
I need to buy a OTG for the ONN box I got because it will not download much of anything. I still can’t view a program in TM because it thinks 2 media sources are running. Right now I’m viewing the game on Sparkel with no issues. Went thru the stuff one’s supposed to do in this situation but didn’t help. Same IPTV provider on both. So I should be able to load TM premium on all 3 boxes I have?
First do a backup and then delete your data. Then restore your backup file.
I have TM on 5 devices (lifetime premium member). I bought three connections from my provider. It works just fine on all devices, including watching multiscreen on one device and 1 screen on another. I’ve never encountered this issue before. I regularly reboot my android box and clear the cache on all my installed apps.
