The Loop and DaddyLive Will Not Play
I’ve searched this topic and can’t find anything reasonably close, so my apologies in advance if this is a repeat.
I installed The Loop and DaddyLive within Kodi, following the instructions on Troy’s Free Cable/Satellite Channels Guide video. Had some trouble getting everything installed (had to repeat the installation process a couple of times, as all of the dependent add-ons would not install initially). I eventually got everything else set up, including the IPTV Simple Client within Kodi.
It all seemed correct, but when I tried to launch something from “Live-TV” in either of these apps, I received an error message telling me that the load had failed (or something to that effect), and that I should look at the error log. I loaded the apps I needed to view and upload the error log, but learned that the Kodi Community Forum has banned both of these Build/Repository/Add-ons and won’t address these issues with Kodi.
So, any suggestions/recommendations on what needs to be done here?
Thanx!
P.S. - if there’s someone out there that knows how to read/understand the log file, it can be found at the following address: hastebin
2 posts were merged into an existing topic: How to Install The Loop Kodi Addon for Live Sports (2024)
