When using the Crew on Kodi, I find it difficult to fast forward or go back. Is there a way to do it easily?
Most of the films or TV shows fast forward sluggish on any app, i usually use the quick skip button on the firestick remote ( outer circle) right is forward , left is back ,up is +10min and down is back 10 mins.
Thanks, I did not know about the up and down, I’ll try it, I know it is easy to FF on Cinema.
