Telegram on Firestick
I have a 4K fire stick is there a way to get telegram some of my kodi groups use it and I’ve been unable to Figure out how to get it on the fire stick thank you
@Art
Its a mesgging app, i dont think it will work on a stick as it does use your phone number.
It is possible to install it on the Firestick using downloader. I’ve never tried it but here’s the link
https://bit.ly/3gzzdYM
I imagine you’ll need a keyboard otherwise as @TP-Dracoo pointed out it’s a msging app and using the firestick remote to enter lengthy txts is excruciatingly slow. But I know some people use telegram to get movies and tv links, so good luck.
I donno if it will work for mesgging and such… i guess we will find out.
Ya I’m expecting major limitations, but who knows.
I realise this is older but is there a current link to put telegram on FS? I’ve now a wechip for writing etc. I appreciate any help. Enjoy your day.
There are downloads for it almost everywhere on line. It’s even in the amazon app store so you should be able to search for it on your stick.
Hi! This link no longe works; would you be able to help out with a new link? I have been looking for the past few days but no luck. I had telegram installed on my fire stick but had to reset the device and now cannot get telegram to install as I am not able to find the correct download file.
