Tea TV T player, no HW+ audio
As many have, recently move to Tea TV from Cinema HD.
Using Real Debris but the audio doesn’t play on built in T Player for good quality links. Does it need HW+ as I can only access HW and SW. Options??
Thanks
Following recent issues I had with Tea TV I now use Titan Player instead of T Player and up to now have had no more problems.
Thanks. I thought T player was the only option though, how do you get around that?
Hey @Benno1969 I use MX Player Pro (from Troy’s RAI) for TeaTV & other movie players…works fine. :cowboy_hat_face:
I’ve had audio issues with MX player that I don’t have with VLC player on these apps. having said that, I don’t believe the latest version of TeaTV permits the use of an external player other than TPlayer.
I’m sure VLC is a fine player…lots of people seem to use it & like it…but MX Player Pro works fine for me on TeaTV version 10.4.1r…and…if there is a newer version, it doesn’t want to update to it…as I’ve tried several times, so I’m guessing what I’m using is the latest version…?
Coulda’ sworn I just went thru this on a different thread :thinking:
That’s my issue, can’t load anything but TPlayer
10.4.2r now. Just saw this this morning.
10-4…I’ll check it out…thnx :face_with_monocle:
Hey Mik…where did you go to see the 2r version of Tea? I’m on downloader at their site & it shows android 1r with release date of 4/28/22.
Nevermind…just went to Unlinked & saw 2r…kinda weird that they have it but the website doesn’t :thinking:
Ya I did the same thing.
Copy…well, I’m downloading it & will see if there are problems with MX working on this version. :cowboy_hat_face:
Let us know how it goes. I usually have a link for the ad free but unfortunately the site I trust is having some issues. He’s working on it.
Sometimes the site will have the previous version listed but when you download it, its the later version.
Copy sktn…1st place I tried was the Update in the app itself…nada…then to the TeaTV website…also nada…so just for grins, I thought I’d try Unlinked & it’s there…now my ??? is…why not the app or the app’s site? That’s just weird…but anyway…I’m now watching something on TeaTV latest version 2r & my MX Pro is working fine also…so, I’m not sure why you were having issues with MX & I’m not…but, if you’re using VLC & it’s working out for ya…then, problem solved & it’s all good. :+1: :cowboy_hat_face:
Hi, where and what is unlinked? Thanks
Unlinked is an app you can install from Troy’s RAI. You add libraries/codes that give you access to a few apps in various categories. Troy has “best unlinked codes” and you can add a bunch of libraries to have access to just about any APK you need.
Thanks, appreciated Miki
There is no option in settings to choose MX player or any video player on Tea Time. When I try to watch something, it made me install T Player. I downloaded app from site with Downloader. Maybe I need to get it from Unlinked? Can you tell me where you chose MX player?
OK @Sandy Let’s start fresh…Uninstall the TeaTV you have…then go to Unlinked store 96960000 & then scroll down to movies & download the Ad Free (AF) Lite TeaTV…middle one. After that…go to Troy’s RAI & download MX Pro player…once you’ve got the player downloaded it’ll show up when you click on external player for watching a link in TeaTV. :cowboy_hat_face:
