Guessing this one has gone by, by as well. Can no longer download it. Left with Bea TV which lately is lagging at points. Had to uninstall Kodi as it has become non functional as usual.
I just double checked and the site is down for maintenance. So you’ll have to wait.
I just saw that. I will try again later or again tomorrow, thanks.
You can get it through unlinked. I just got it today. Use it with RD
Syncler is awesome and stremio is also great
Kodi non functional as usual? It works great if you do maintenance such as deleting cache. Especially with Seren. Rd must be used with it though. Stremio your best option, takes a little to set up but once your done your settings transfer from each device with a couple of clicks. Vpn mandatory with it as should always be used.
