I told you guys it was “the gooogggly powers that be”, but nooooo, everbody was like–that old @itzme don’t know what the #***# he’s talkin’ about….so PFFFT….
Google play store doesn’t recognize this device as compatible with both apps so in the past I download them to my Formuler Z11 Pro Max and Buzz X5 SPECIAL EDITION which Google recognizes as compatible. Then using a file manager I send copies to my SK1 and this has always worked. As soon as I updated the SK1 apps this time when I open it, I get sent to the playstore and shown a list of similar apps that are compatible but yours aren’t there. So there’s no way I can get the updated versions to function. So for now I uninstalled them and put the older versions on and they’re working flawlessly again. Hope somehow this gets fixed or the older versions keep working.
P.S- If I try disabling playstore as soon as I open your app, I get a pop-up saying I need to have Google play store for this app to function and can’t get past that pop-up.
Just loaded the TDUK Cache Cleaner and App Killer apks and they work PERFECTLY on my ONN streaming boxes. They are well worth the money ! THANK YOU !
I do have an issue I hope you can help with. I have 3 streaming apks I love use. I love them but they all buffer terribly. I believe it is the built in internal players that are the issue. Apks like Flix Vision, where I can pick an external player like MX Pro. or VSP. run smoothly. But APKs like OnStream, Streamfire and Sportsfire that don’t have a selection for an external player in the ANDROID TV version, freeze and buffer terriblly. How can I fix this. The cellphone versions of these apks let you pick an external player, but not the Android TV versions. Any suggestions? I love Onstream, Streamfire and Sportsfire, but this buffering is the worst !
Is there a,way to use an external player with these apks??
I typically stay away from these standalone APK’s like Flix, Cinema, Bee, Onstream, Sportsfire, Streamfire etc…..Streaming for 10 years and IMO they all experience terrible buffering and it’s not on your end. I would recommend learning KODI or Stremio and a good IPTV service or 2. These APK’s come and go but I see so many posts about issues with them
