Tablet trouble with EPG
This is my first time posting and I thank you for allowing me to be a part of this group. I am trying to learn as much as I can and enjoy these topics. I am using an Android tablet and am having trouble finding an IPTV source whose EPG is tablet friendly. I enjoy watching live tv but most of the EPGs that I have tried go off to the right of the screen when I try to scroll down. Sorry for the long post and any info would be appreciated. Love the Troypoint!!
What are you using to play the iptv stream?
Can you please give us the make and model of your tablet and which IPTV Player you are using. Makes it easier to focus a search for exact info for either a fix or what settings are needed. Thank you.
Samsung S5E and I use IPTV
I play IPTV using TiViMate. So what player app are you using,
IPTV Smarters and it is an samsung tablet
Yup got that. Smarters was the last piece I needed. I know smarters as a stand alone IPTV is not very feature rich and usually is modified by IPTV services for their own platforms. So reasearch time. I find any info I’ll post it.
IPTV Smarters on a Samsung S5E tablet
Could you try XCIPTV player and see if you like it better? its highly recomended for tablets.
Thank you so much I will try it tonight!
I researched everywhere and so many have problems with Smarters on any device not just your tab, but I’m sorry I could not find anyone with your exact issue. I think TXRon is on the right track, as I don’t know if TiViMate will work on your tab either.
Ive read where tivimate is working on it but issues still with touch screen. I saw XCIPTV mentioned to work well with touch??? I cant test :face_with_raised_eyebrow:…guess I need a tablet next :joy:
With XCIPTV’s channel icons set up in a Hollywood Squares block…I would think on a touch screen tablet that would be an easy way to pick your channels. XCIPTV is what I used to always use before I discovered Tivimate…never cared much for Smarters.
I use IPTV Stream Player - it downloads my EPG upon startup.
I use it on a ZTE Android 10 tablet & a Samsung Android 8 (9?) tablet.
Just search ‘IPTV’ in Google Play Store & it will pop up.
HTH!
