Nord VPN Installs but will not run. After installing from Google Play all seems ok when selecting “open” I get a blue window for a few seconds then the “open” screen reappears. This is a continuous loop.
Anyone having this problem. I have spent 2/3 hours with Nord support. No joy yet
Try un-installing and if you can install it again from nord website instead of play store
Thanks for reply. Got a link from Nord support old version and it installs but the key logo when connected does not show. Will continue trying, again thanks. Tange
Kinda strange, usuually you go to source for a more updated version than the playstore. FYI the playstore always lags behind in updates unless you are in their fav adware group of friends.
