T95z ask permission
I have the T95z box.ever time I click on the Kodi icon,it ask for permission,so I click on continue it tells me permission denied.How can I get around this.this is also for Netflix
well,I guess nobody has had this problem thx
I have 2 T95Z Plus Boxes running strong over 5 years now. I have never seen that message. When you say “click on the KODI icon”, is that by chance something that came preloaded on your box? If so my guess is it’s an older outdated version. Best bet is to install a Fresh version of KODI from the KODI site or from the Troypoint Toolbox
I had a friend who knows little about what I was going thru.he fix the problem.he went into setting and found the problem.thx for help your help.
If you could, would you please share the solution you found? It may help others in a similar position and will also add to our knowledge base, so that we can help. Way to go and congratulations.
ok I will.my friend left but I’ll talk to him about this
ok here go’s.go to setting click on APPs,click on what you need permission(for me it was KODI).go all the way down to permissin click on that and then click on the Microphone & Storage. and that it.hope this will help somebody
Tx @azmickey. Appreciate the info. Have a great weekend.
Hi,Miki.your welcome.my friend was the one who did it for me.I did very little,LOL.enjoy your weekend.My next project is hooking up my T-Mobile 5G.
Yeah, this is similar to what I posted this morning about zip files. On the new Android OS you have to go into the app permission settings and set it to “always” to get everything to work correctly. Also uncheck the box that says “remove permissions for unused apps”.
thx .I’ll look into that thanks lot
I have installed Kodi on T95Z… I start the initial screen that has for Kodi to be allowed to ? no matter what option I choose I get a message “dont have permission” I cant get past that message to add APK’s Help appreciated.
