Syncler Vendors for Beta V2
Originally published at: https://troypoint.com/syncler-vendors/
Provided below is an up-to-date list of Syncler Vendors which are now required for use with the new Beta V2 release. Syncler is one of the most popular streaming APKs available for the Fire TV Stick and Android TV Boxes. The stable version should be available sometime in the near future once the developer has…
LOBSTOR is a new provider for Syncler+ and offers a range of package installs for the new Beta as well as a comprehensive file for V1. The files are maintained and have undergone a lot of sanitization over the last few months making them far superior to the existing (old) sources. For example - the code to scrape certain sites is out of date in all cases. This means users do not get results from certain providers contained within these files and it just slows the search down. LOBSTOR is continually monitored and maintained to ensure the scrape is accurate.
My only problem with these packages. These tend to not pull correct links. I get say like Mr & Mrs Smith when I want to watch Tracker. I have to read the titles to make sure I get the right show and episode.
At least the Beta of Syncler lets you see the title and episode now.
Agreed - which is why i set up LOBSTOR. All the old providers are full of deadlinks and foreign filters clogging up the returns. I’ve spent a lot of time sanitizing the links and documenting what the plans are to keep on top of things. Beta does process the JSON files differently as Tracker - Equalizer - Spinning Out - Ghosts…. to name a few return all sorts of results. I have reached out to the dev to get clarity of what beta is doing with the JSON files compared to V1 (which seemed to return less spurious link from the exact same file)
Any word on the lobstor vendor results. It’s getting kind of annoying at this point. I thought it was working good for a minute.
Apologies. Too many forums to update. My main updates go on reddit. The syncler dev came back to me. It’s nothing to do with the vendor urls it’s officially a bug in beta. He now knows about it and it’s on the fix list. Nothing vendor url providers can do at this point. It also answered why many users reported seeing ‘improvements’ in the number of links found in beta… it wasn’t finding more, it was just finding spurious links on top of good links.
I appreciate the response. Thanks for what you do. :pray::grin:
These vendors results are a joke. The whole process of syncler is, well kinda of, ridiculous. Beta or not this recommendation is sub par considering the history of recommendations from Troy point.
Official Syncler, not Beta still brings in better links. The reason they use this type of setup is to avoid being shut down. The app itself doesn’t do anything without the 3rd party packages/vendors that they don’t have anything to do with. If you don’t like this, try Umbrella Kodi Addon.
Is there anyway we can get you to make a tutorial for installing wako config for syncler?
There is now a dedicated vendor url for Syncler V2. The old Syncler-lobstor url is no longer supported and will be phased out. The new url is bit.ly/lobstor2
This vendor url contains 30 individual packages that you can pick and choose sources from making it extremely configurable for individual needs/tastes. Alternatively the default package gives you the top 20 sources (and you could add to this if you wish)
I set up Syncler+ bought the subscription and set up the two vendors. Hooked to my Realdebrid.
Now I am trying to figure out what is so great about this? It doesn’t seem to offer anything I can not get on many other apps. It is entirely possible that I have no idea what I am doing and have it set up wrong. I do see both vendors and packages in the settings. Appreciate any insight on what I am missing.
Ad-free, tons of settings, great UI, no malware, constant updates that’s why I like it. Why did you pay for Syncler+ before first trying with the free month of service???
