Just wanted some recommendations. Is the plus version a good move? I notice the cost is minimal and I get several dead links currently. I have RD installed and just curious if its worth the upgrade. The movie/show selection looks great and basically ive just had syncler “sitting on the shelf” . I set it up via Troypoints direction soooo should I take that next step:)
Absolutely worth it and my favorite combo.
Cost me 15 bucks a month (cdn) it’s worth it.
Make sure you install the express packages. They are on troy and both are awesome.
Thanks, I will look into the express pkgs.
All set up, express etc… Troypoint site made it a snap. Now the testing begins with Dune:)
Like any other torrent or streaming service if it’s not leaked or out on a platform you will only get cams.
Dune was leaked I’m pretty sure. The best indicator of a movie being the quality it says is how large jt is. The more the better.
But enjoy man! I’m glad you got it setup.
Thanks. This was a great addition. I have seen ZERO buffering after 3 movies(only paid attention to one:)…but kept it going to see performance. It is by far the best experience ive had compared to all other apps etc. I do believe that with Tivimate for live tv and series and syncler for the rest that you shouldnt need anything else. I should have put forth more effort on syncler earlier. I think I gave up after it asked for provider packages and put it on the back burner. But now all is good… thanks Dracoo for the express tip because I might have overlooked that.
Syncler+ is a bargain for what you get in return. It’s been very reliable, provides lots of links, and very rarely buffers. For those like subtitles, it consistently provides a list of subtitles to choose from.
I just downloaded and set up Syncler + with RD this morning. All I can say is WOW!!! Wish I would’ve done it so much sooner.
It truly is amazing
I use Syncler with RD and get many links that I don’t get on other APKs. My questtttion is what makes + better for the price? Thanks
I really like Syncler! The sources I get are great however they are all torrents therefore I think a VPN like Ipvanish is a must for this app.
Enjoy
The express provider package. Has the edge over free.
Faster and more links. And lots more support for it.
What is the best way to pay for it now . Been doing a lot of reading here and some seem to be having trouble with the+ and paying any suggestions
Buying keys from syncler is done with crypto. People struggle with crypto so they have to use the approved resellers. For PayPal and such.
I used one and had no issues but I also have crypto using coinbase.
I suggest buying from syncler with crypto.
Thanks I have no idea about crypto I will have to look into it thanks
Linked.
Hope this helps. FYI coinbase does do I’d verifications last I checked. But i was selling too.
Little off topic sorry.
Syncler is the best. Make a topic on crypto or pm me or something for crypto.
Thanks I’ll check it out . what about prepaid visa card
So what would be the advantage if you already use RD? I get really good links and videos are great with RD, so having + give me much more links and better quality? Thanks
I know many think syncler is a wonderful app. For me it does absolutely nothing, and I certainly wouldn’t pay for it. Anything it does I can do myself But it proves one thing, you make an app, someone will like it
