I subscribed to Syncler and installed the Kosmos package. Having problems trying to install the Express Package.
Is that package worth the persistence to try and install it.
You can only use express if you pay for syncler plus. And if you have s+ use it.
Also as a patron I have a easy install method for provider packages in the exclusive guide btw.
If it works, you should be good to go. I usually install both if I can.
Thank you for your reply. I do subscribe to syncler. I already have Kosmos and real-debrid installed. It was the express package that has been a pain getting it to install but, today I eventually used the url below for Express and it worked https://raw.githubusercontent.com/itzAki07/scraper/main/scraper.json
For the Kosmos package I used http://kosmos.syncler.ml/
So all is good.
Im glad you got it working. I highly suggest looking at the exclusive guide as I added better install methods for syncler with scrappers. And I also added some settings as well.
Hello @ TP-Dracoo, The guide? is the guide what was in Anonymous post? If not, where do I find your guide.
