Syncler+ Not Working w/VPN Enabled
I currently have 3 nvidia shields devices in my home all having ipvanish installed as the vpn of choice. I haven’t had any issues with syncler+ while the vpn is enabled on 2 of those devices. Yesterday I added syncler+ on the 1 nvidia shield that it wasn’t installed on. After completing the install and adding real-debrid, syncler wouldn’t work. No Movie, TV, In Theater, etc. thumbnails appeared on the home page. After disabling the vpn, the app worked perfectly and I could stream w/o issue. Still no issue with the other two devices with vpn enabled. Any suggestions on how to correct this issue?
Are the working others using the same vpn servers?
I did some checking and found several movies would not even appear on a page after I clicked on the poster in the category in a variety of categories. Eventually, some did open, and I could play them. Still some never did open up and would get a pop-up stating an error occurred.
I tried force stopping and cleared cache. I tried rebooting my device. I tried with and without my vpn. Nothing seemed to remedy the issue. Then all of a sudden everything seemed to go back to normal.
I have no idea what happened. Maybe there was a glitch on their end? Some are still a bit laggy on displaying the play page after clicking the poster, but every poster I am clicking on does show the next page.
Me thinks Syncler+ is having some issues at present and are working on it?
Btw, I am using Shield Pro, Express VPN and connected to an Atlanta server.
