Syncler newer Packages
What Syncler packages do you recommend, I used the the Provision App the last time I had to install Syncler. I saw this on Troy point article and was curious if anyone has used any of these newer packages. Please let me know your feedback and if I should change my current installation. Thank k You ahead of time my troycepticons!
The bit.ly shortcuts will make it easier for proper input.
Fast with lots of links:
https://bit.ly/syncsquizz
Most Links but not as fast:
https://bit.ly/syncitz
Fastest but fewer links:
https://bit.ly/syncdemons2
I already have Squizzle - Ultimate installed, but I decided to download the https://bit.ly/syncsquizz and check it out.
The package did download and install, but I believe it is Squizzle-Ultimate. During the install a pop-up very briefly appeared and I believe the shortcut url pointed to the Squizzle - Ultimate package when installed. So, other than updating the package. It is not a new package. Just has a new short url for convenience. (but I could be wrong?)
How To Install Syncler APK on Firestick/Android TV (2023) (troypoint.com)
Powerfader did you notice any difference, I seem to already have a lot of 4K links. I’m just wondering is the juice worth the squeeze to reinstall or update my scraping packages.
Are these urls for Syncler+? I use the free version.
I don’t pay for the scrapers. I only pay to have Syncler+. However, as I have stated before. There is a very good likelihood I will not be re-upping on my Syncler+ sub. Stremio is just about as good and it’s FREE
Hi Powerfader,
I’m a Stremio user as well. I like to have a couple backups. Sometimes I have to check different apps to find a move or series I’m looking for.
I’ve been using Tubi more these days. I enjoy christmas movies and Tubi has been airing some good one. Networks have started the 2023 holiday movie season.
I’m sorry if this is a newbie question but I’m using Jakedup at the moment in Syncler and I’m looking to install Magnify Fast.What is the proper way to do this?Thanks.
Try this , for me it had 4 different options to pick from. Hope this helps!
Https://magnify.pages.dev/vendor
Thanks :slight_smile:
This 100% does not work
That’s strange, I have been using it for months and just watched a show tonight. I get plenty of links also.
