Syncler MediaCodecAudioRenderer error
MediaCodecAudioRenderer error, index+3,
Format+Format(2, null,null,audio/ac3,null,-1, en,[-1….
AudioTrack init failed 0 Config(48000, 12, 40000)
Nevermind. A reboot of FireCube seems to have fixed it.
looks like missing codec in the exoplayer. Try changing the player.
@denadavidson99
Which video player are you using? Also update syncler, that verson is old.
Thank you, I will keep that in mind should it happen again. Thx
I didn’t realize I was on an old version of Syncler, I will definitely update it. thx
The time tested re-boot works wonders…many people pay big bucks to have guy on the phone have you do that :joy:
Reminds me of " IT Crowd" the British comedy. “Have you tried turning it off and on again?”
@denadavidson99
1.3× is syncler version which fixes exo player bugs. If this isnt solved pm me i will reopen. You had marked a solution .
I uninstalled the Kosmo and Express packages and reloaded them and mine started working fine against.
