Syncler issues installing needing url
Anybody know to get syncler beta to install provider package kosmos. i get to the point where i enter the activation code then it asks for the url? What do i enter here? Any help would be greatly appreciated. Anybody else having issues with syncler to get loaded and running properly?
how do i install kosmos provider package in syncler. I get to the point in settings under provider package it Says install
From raw data
Status done
Progress unknown
If i try to find a link for a tv show it says provider package not installed. Thanks for the help anybody
@Chris10091
No need to male another topic on the same subject.
Still getting same message failed installation for the provider package kosmos after entering activation code
@Chris10091
Because you are missing a step. I have done thid thousands of times. Take your time. Komos just installs the provider package, copy and paste into the url syncler/install. Hit enter click done at the app. Best with 2 devices.
Or install the provision app which does it for you.
