Can I uninstall the Syncler Installer after I have installed the Syncler+ App? My firestick has little memory left and if I don’t need it then I would like to get rid of it.
Thanks!
Yes after you are done with the install you can delete the installer I just finished setting up my other Nvidia shield in the bedroom and I deleted it after as per the instructions from tp. And welcome to the community I believe if you do a search with the search button up top there is a syncler setup
