Syncler Beta 2 Setup & First Impressions Video
My opinion JakedUp is better. Why is beta, a beta version for so long? Lol
I have the stable but have only used the beta so far.
I have heard in may sometime that there will be a good update with a easy pay system and a longer sub? Now this is just hear say but i do believe they will make this app better and easy for all to enjoy :wink: just sayin!
So far so good. Great video and clear instructions it helped that i had syncler already so i was familiar with how it worked.
I haven’t heard of changes in the pay system, but the developer did say he was considering 2, 3, and 5 year subs.
He’s doesn’t seem interested in lifetime subs and I agree with that 100%!
My Apologies about the syncler pay system, I was wrong. It is a new account system.
Tried to install syncler beta but using the installer to download the beta version just installs the stable version. Is the beta version gone along with the lobstor package system?
As far as I know the beta is available along with lobstor package. Make sure the beta is checked :heavy_check_mark: at the top of the intstaller. Hope this helps!
I am using a Formuler Z11 Pro which may have caused some install issues? I reset the box and re-installed both the stable and beta versions. Took a couple of attempts. Seemed to require stable install first and then beta. Not sure the developer is still working on this project; the beta version hasn’t changed for months. Thanks for the reply.
Not sure if anyone is having issues with syncler but would like any info or help on a fix. The movies and shows begin to scrape for links but ultimately come up with zero results. Real-debrid is active and my syncler is active not sure if i need a new repository or what. Thanks in advance for the help
I’ve been using Syncler+ somewhat successfully for a little over 2 years now. Sometimes it works and sometimes it doesn’t. I had no idea there was a Syncler 2.0 until today. I also noticed most of the discussions are from a year ago. Does anyone recommend deleting 1.0 and starting all over with 2.0? Is there a significant reason to do so, or simply leave sleeping dogs lie?
javax,net,ssl.SSLEException:Unable to parse Tls Packet header Can’t get any links to open in Syncler I get this response along with Exit and retry but it keeps come back to same error.
Anyone having problems with Syncler?mine wont open anymore,would appreciate any comments.
Had to uninstall and reinstall my syncler+ last week. The beta was not working for me at all so stuck with the stable version of syncler.
I had to do the same thank you for your comment
They have announced that they are releasing Version 2.0 on Friday so I would suggest waiting until then and hopefully everything will be 100%. We will have a full setup video early next week.
Troy, you definitely need to fast track this guide since the Dev is offering 1 month premium to everyone for free so people can try the full features for free.
  • Launch: Friday, May 23, 2025 5:00 PM UTC
  • 1 month of premium — free for everyone.
I’ve been using the beta the release is based on, and it has been great. I know many don’t like to pay for software, but it is great to have alternatives.
Syncler V2.0 Setup Video now available!
