Syncler Beta 2 Setup & First Impressions Video
There is another Syncler file (for both stable and beta) users can now use… here is the beta…
V2 (Beta): http://bit.ly/syncler-lobstor
See readme at Syncler/README.md at main · h53h54h55/Syncler · GitHub
The URL installs multiple package options for users and the dev is adding more daily.
The file has also been sanitized to remove deadlinks, foreign language and anime content (which the older alternatives were bringing in)
This happened to me. I just went back into the Syncler installer. Turned off the Beta switch. Closed the app. Then went into apps and force close Syncler installer. Clear cache and data.
Opened Syncler installer and switched on Beta.
It did install the beta. It was like 45mb. Where the old original version is 98mb. The installer did turn off when I choose to install. It kicked me out to my Home Screen.
I am using nvidia shield pro.
I will say when it was done. There was quite a bit of a delay for it to install. Then it did show up.
I do love the new providers provisions. Jakedup is da bomb. Sooooo much better than the old version.
It shows me torrentio, piratebay etc. The old version of Syncler was just not pulling links like used to. No matter what package I used.
I do hope you get it figured out.
Maybe just a hardcore restore on your device.
Yes that worked for me.
You might add
Thanks for your response.
Thanks for the link, works great on my beta. Didn’t bother on the “stable” version.
Syncler Beta is working really well.
Stuart Woodhead has created the only source url that you need.
Best package/vendor for Syncler:
V1: http://tinyurl.com/syncler-lobstor
Both of these can be used in Express with no need for additional packages required. Adding more results in duplication, slowing down the process. And they both work flawlessly.
Reddit
r/synclervendors
Does anyone know if my Syncler is set up as per Troy’s tutorial using Orion if I can or should add this LOBSTER url?
I am a Syncler subscriber. I use RD and Premiumize. I use jakedup.I find just player the best player, especially for Subtitles.
r/synclervendors - reddit
One of my Onn boxes down loaded Syncler Beta without any issues and is working great.
My newer Onn device won’t download it even with all permission.
I’ve reinstalled the Syncler installer, rebooted the device, cleared cashe on all apps and still refusing to install. After the downloader is complete my screen goes to the dark side and reboots to my Wolfy home screen.
Anyone having the similar issues?
Jeffrey
I did have a similar issue on my shield.
I did some of the stuff you did. I deleted the Installer app. It did not work at first. So I force stopped app. Cleared the cache and data. Tried again and it worked. After my installer downloaded the beta. It went back to my Home Screen. After what felt like an eternity, it showed up installed out of no where.
Just check in your apps and make sure it’s not in there. Good luck.
It did take a reboot to show up in my first Onn device.
So I think your right to say to give it a chance to pop up. I had the Installer in an external storage but removed it hoping that presented the issue.
I’m sure it’ll pop up, somewhere, hahahahaha. No other reason it shouldn’t download.
Thank You for your time.
Much Appreciated.
Is the apk on downloader?
You always have to do a restart on onn.
I’ve downloaded the Installer from both the Downloader & their website and rebooted multiple times after installing. I cleared the data from Installer after each attempt as well. When after the Installer stops, I get a black screen for 30 or more seconds and then it takes me to my Wolf Launcher home screen.
Made the mistake of uninstalling Beta on the Onn box that it did load on, to maybe see if I could pin point the cause and now it won’t reload on that box either.
This one has me scratching my head.
I have Beta on a onn, a buzz 5 and a nvidia shield.
However, it is called Beta for a reason.
Please review reddit r/synclervendors
This express is for v1, so maybe just wait until all the bugs are fixed. They don’t seem to have a plan for updates. This provider is the only one you need.
Syncler has worked great for me and after installing it on my new Onn 4k Hd has been flawless.
However that said. Loading it to my 2cd Onn and every time Syncler does an upgrade it wipes everything clean. My sign in, packages and settings. Tried uninstalling and installing a new app and tonight after an upgrade, the same thing happened.
It’s resetting my app???
This isn’t happening to my other device?
Any Help would be great. So far I’ve had to rebuild my app four times the past two months.
Much Appreciated
Jeffrey “Stumpy” Hardin
I have both, the Syncler+ Stable and the Beta. I use the JackedUp package in Beta and Squizz in stable. Which package is better or does it not matter.
I use beta now more than stable and use Full Lobster Dinner. Get good links and have great success!
I do have stable on my box and projector downstairs and use jackedup which I think works awesome :ok_hand:
