Swapping Micro Card in Nvidia TV
I have a new larger Micro memory card to put into my Nvidia Shield TV device. I know that some of the apps are on the old card and many of my apps have information on it. Can I take the old one out and connect to a laptop and transfer all the files to the new one and then install the new in Shield or will I have to simply start from scratch and reinstall everything. Thanks
This might help you out if you need more info use the search button up top there is a lot on this topic and has been discussed before good luck hope this helps. Download - Send Anywhere (File Transfer) (send-anywhere.com) 6
