I have a 4K on my son’s small TV. It has zero widgets available (none of my boxes or sticks have it available). I tried to update SS direct from the RAI in hopes that it popped into my widget options as mentioned above, and it didn’t work for me. At this point, the fact that I can’t figure it out is driving me more crazy than the actual functionality of the widget. ![]()
Are your 4Ks FireTV 6 ? The Max FireTV 7 and latest SS both updated should have this corrected and you should havd the icon.
It is 6.2.9.2 on the 4k…but the widgets don’t work on my Max either.
Use a CUSTOM LAUNCHER with WIDGETS on the NVIDIA SHIELD TV! - YouTube
Startpage Search Results
https://www.startpage.com/do/dsearch?query=widgets+on+nvidea+shield&cat=web&pl=ext-ff&language=english&extVersion=1.3.0
I have always used Wolf, and love Wolf. It has been great and easily customizable. Im starting to wonder if I should try others to see the differences. Would other launchers be easier with the widgets?
I’m using Wolf as well and I like it. I’ve now installed the VPN monitor dot (free replacement for VPN Safety dot) making the need for the SS Widget moot. I basically gave up on missing widget issue and moved on.
If interested in installing the VPN monitor dot check out Troy’s how to at https://troypoint.com/?s=Vpn+monitor+dot. Good luck.
I have had the dot for years and I still want the widget. It will drive me crazy.
