Surfshark issues
i have been using surfskark for about a week now. i find that it freezes a lot. u don’t have disconnect button like ipvanish. it’s good to have that after u have surfed the web
Says you’re logged in. What happens when you click “Settings” on the lower right.
Recently I have had issues with Surfshark VPN disconnecting my internet access. I cannot receive emails or access websites. There is a message under my Network saying there that wifi is not connected. If I disconnect Surfshark VPN, all if fine. How can I remedy this?
@hammer have you read thru this post, as it might help….
Surfshark "Clean Web" blocking IPTV services
So I have a friend who is running the same IPTV service and Surfshark as me, he gets the spinning wheel on some of the channels and when he changes Countries that channel will work but others won’t, it doesn’t matter if he shuts SurfShark off or changes Countries, he still gets the same error. I loaded his IPTV service with my same Surf Shark settings and had zero problems. Is there a setting in Surfshark he should be using, or am I missing something?
