Surfshark Dedicated IP Set Up on ONN TV Box
I just purchased the Surfshark dedicated IP add on and went through the set up on my PC and Samsung galaxy s21 FE. However, when I open surfshark on my Onn TV box it does not show an option for choosing (setting up) the dedicated IP. Has anyone figured out how to do this?
Well, I chatted with surfshark support and they told me dedicated IP is not available on anroid boxes yet.
Was that in their advertising? Will they at least refund you?
No it was not in their advertising. Also, as you read through the material they let you know that simply using the dedicated IP can provide less anonymity because the dedicated IP is attached to your email account. However, you can choose to (for lack of a better phrase) have surfshark delete your data from their system but you will have to set up the service on new devices manually with some special “keys” that they will give you. What I seemed to notice if you go this route, is it voids an option for refund.
Additionally, I don’t think it is all that necessary to run the dedicated IP on the firestick, Onn, or other such devices (at least for me because I do not surf the web on those). The normal VPN works on those devices the same as it ever did.
Hope this helps.
We pointed this out a few weeks ago and pushed this out to our email list regarding not working with Android TV or Fire TV.
Oh I totally agree. I was just curious. I have absolutely no need for a dedicated IP on anything I have. Many years ago, yes, not now.
I don’t get on much here but I bought the onn Walmart device and looking for a video that shows me how to install correctly… I know troypoint has to have one
He does. Try the search engine on the insider first. That doesn’t work, Go to Google search for your device and put Troypoint in the search and that should bring it up.
Out of curiosity, Why do you need a dedicated IP on a streaming stick? Are you logging into somewhere that demands you have it? On a PC if you’re doing remote login to a work server, I understand it but on a stick?
The advantage dedicated IP address is when streaming IPTV and a lot of the public locations get blocked and if you search the forum, a lot of people have been having trouble running the VPN and it interfering with the IPTV stream.
The dedicated IP address is supposed to solve this problem. Too bad it doesn’t work on the android system, which is kind of stupid.
Has anyone heard about Surfshark or any other VPN planning on working with android systems for a dedicated IP address?
Yes, will be out sometime in 2025. I’ve been using the dedicated IP address through my Asus router with VPN activated and it works great.
I’ve used a dedicated IP on my Onn devices using SS and it works just fine. Never a problem. Mostly I don’t but it depends on speeds at times.
