Surfshark Bypass & Route via?
Good question. Because Ive had SS for years I’m on the understanding that if n neither is used and you have a kill switch You’re being protected because once the internet surf shock drops I have lost internet on the app that I was using that is really good question I check on my debrid services and on all the services they’re using the surf shock IP address so I believe you are protected but why have a switch to say you want to veer it everything should be veer to it
I never use the live TV app on the BuzzTV P6L and use the Tivimate app instead.
