I have had several issues with surfshark on my Mac using Google and Safari as the websites will not come up when I have my Surf Shark VPN on. Is there a method to resolve this issue.
Its seems to be a common issue with the surfshark app. You can try using the bypass settings in the app and maybe get lucky however I havent. My solution at home is have my phone use surfshark through my router and I have no problems. They do have an issue with the app and not sure if a fix is in the works.
