Surf shark vpn not working with streaming
Can’t steam live tv with surf shark yet could with iPvanish. Any help is appreciated.
Are you using a legit service or iptv? Is it buffering or are you unable to login at all?
Surfshark and my live TV is working fine. Every location I switched too worked as well. I have Wireguard turned on, if that’s any help.
I have Surfshark turned on with wireguard location Chicago. It is working with my iptv service. It is not buffering. Hope this helps.
I was having issues with SS and recording. I would only get a minute and it would stop. I cleard the cach and data files in the app and redit my login and choices and it all seems to be working just fine now. Worth a try. 2 devices, Shield and ONN box.
It doesn’t matter whether I’m on Stremio or my Iptv, both apps will buffer forever until I turn the surf shark off. Suggestions/Cures. Thank you
I am having issues with SS streaming also. It will only stream if I use servers outside of the US. I’ve used it for a couple of years streaming VS with no problems using US servers. Suddenly stopped working. I get a message no internet connection. I am using Nvidia shield. spent more than an hour with SS chat. No success. Any ideas.?
Not sure what “streaming VS” is.
I guess the first question is: Do you have any issues when trying to stream something like “NIght of the Living Dead” with the VPN on with local servers or with the VPN off?
Just thinking, SS recently had an update. Are you using the latest version?
And what steps did SS have you perform to resolve this issue?
