I switched from IPV to Surf Shark and am happy with my decision. The only problem I have is that when I want to print something, I have to Pause Surf Shark. Any help is appreciated.
That’s common as the VPN assigns a new IP. So in this case I would “white list” or split tunnel your printing app.
Thank you Miki:
Trying to figure how to “white List” my printer and will update you. Thank you for the quick response.
Jim
Oh it’s split tunneling. You add your printing app to a bypass list so it doesn’t use the vpn. I think with SS it’s called “bypasser”.
